valve seals
Old Mar 8, 2011 | 11:39 PM
frenchy107's Avatar
frenchy107
valve seals
just replaced my valve seals on my 4.9 today, the air tube in the head made the exhaust valve on cylinder 2 difficult but i got it. gonna put the head back on in the morning, really hope this is the last time i have to take that head off!!!
Old Mar 9, 2011 | 07:03 AM
Lazy K's Avatar
Lazy K
Good man. If it needs done it needs done.
Did you think of doing it with the head on?
Old Mar 9, 2011 | 08:27 AM
frenchy107's Avatar
frenchy107
not sure how id be able to take the valve retainers out without taking head off, compress the spring push the valve down and then give it a good firm tap.
Old Mar 9, 2011 | 10:32 AM
Lazy K's Avatar
Lazy K
A couple of ways. If you have compressed air you can, with both valves in the closed position, connect it to one of the cylinders by an adapter in the spark plug hole and that will keep the valves from dropping.
I have also heard of guys getting the piston to TDC, with valves closed and filling the cylinder with nylon rope, through the plug hole, to keep the valves from dropping.
You need a lever type valve spring compressor for both methods.
However you got it done and that`s all that matters.
Old Mar 9, 2011 | 02:43 PM
frenchy107's Avatar
frenchy107
head gasket was leaking oil anyways, so i figured do it all
