460 Truck Engine
Old 01-21-2017, 12:03 AM
loveless41908's Avatar
loveless41908
loveless41908 is offline
460 Truck Engine
I've got an 86 f250 with a fresh 460 I rebuilt. Bored .040 over, rebuilt heads, rv cam (can't come up with duration off my head .5 something) with edelbrock performer intake and 750 carb. The timing set I bought had three keyways in the cam gear. I read into it and decided to use the advanced timing keyway. Truck runs great, did a proper break in before I tried to open her up. First thing I noticed is the engine hesitates and loses power under heavy acceleration in the 3000/3500rpm range. Is that because of the advanced cam timing or the high lift of the cam itself?
Old 01-21-2017, 05:26 PM
ciamcoop's Avatar
ciamcoop
ciamcoop is offline
Could be carburetor tuning, could also be cam timing. Generally when you advance can timing it brings the power band down lower. A .500 lift cam should pull hard into the 4000s. When installing a cam you should always degree it in according to the specs.
Old 01-21-2017, 08:17 PM
loveless41908
Totally agree with the cam timing, think that may very well be my issue, need to get to my cam papers and adjust it the way they recommended.
Old 01-21-2017, 11:58 PM
loveless41908
Found the paper that came with the new cam.
Old 01-22-2017, 10:09 AM
ciamcoop's Avatar
ciamcoop
ciamcoop is offline
Perfect. Now do you have a degree wheel? You're gonna kick yourself, but you need to pull everything back off the front of the motor and degree it in. It's pretty easy to do, if you need help I would guess there are YouTube videos you can find to help. You'll need a piston stop and possibly some offset cam keys to get it perfect. I'm not sure on the years, but I've read that ford advanced cam timing for emissions, so if you advanced it even more that could explain your problem.
Old 01-23-2017, 08:03 AM
jas88's Avatar
jas88
jas88 is offline
Timing was retarded for emissions, not advanced.
Lngbeard
11-10-2009 10:28 AM
shortbed1
01-28-2009 07:38 AM
73F100*8Mile
10-15-2007 07:36 AM
scottie2hottie
09-30-2004 08:53 PM
85351ho
05-17-2001 01:21 PM
Quick Reply: 460 Truck Engine
