Installing Power Assist Steering - 1971 F-100
Old 01-15-2017, 06:18 PM
treverd's Avatar
treverd
treverd is offline
I have a power steering setup from a 1973 F-100.
I want to replace the tie rod and drag link before installing the new system.
Do I need to purchase the drag link and tie rod for a 73' or 71'?
What is a good reliable source for these parts?
Thanks,
Trever
Old 01-15-2017, 09:01 PM
ultraranger's Avatar
ultraranger
ultraranger is offline
I'm guessing the PS gearbox is a Saginaw unit. Does your truck have the stock front drums or Dentside front discs?
Old 01-15-2017, 09:53 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
You use the linkage for the knuckles, that's where the difference is. There are two different lengths on the drag link, 30 3/4 and 29 1/2, measured from the left tie rod end hole to the far end.
Old 01-15-2017, 10:30 PM
treverd's Avatar
treverd
treverd is offline
Steve and Jared,
Thank you.
You are correct, the box I got from the 73' is a Saginaw unit. My 71' has the stock front drums, I will be keeping those for now.
Sounds like I need to measure my 71' current drag link and order the replacements based on those.
The 71' drag link / tie rod will work with the 73' pitman arm that came with the steering box?
Old 01-15-2017, 11:25 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Yes it will.
Old 01-16-2017, 02:28 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Question Installing POWER ASSIST Steering - 1971 F100
Do I need to purchase the drag link and tie rod for a '73 or '71?
Is your 1971 F100 2WD or 4WD?
Power assist P/S was only used on 1973/75 F100 4WD, 1975 F150 4WD & 1973/77 F250 4WD (High Boys).
F100/150 4WD's used Garrison power assist, these F250 4WD's used either Garrison or Bendix power assist.
F100/150 parts with one exception are not the same as F250 4WD with Garrison.
ALL the power assist parts are obsolete, very hard to find.
Power assist use a P/S control valve and ram cylinder. The manual steering gearbox is used, because it has nothing to do with the power assist system.
F-250 restorer
09-25-2015 11:06 PM
sc00ter
06-01-2011 09:37 AM
Eddie Swan
10-09-2005 12:00 PM
Faithful Old Road Dog
15
06-26-2004 01:33 AM
Cornelius
09-23-2003 03:22 PM
Quick Reply: Installing Power Assist Steering - 1971 F-100
