Socket size?
Don't rely solely on the socket. Try to get a strap wrench above it to assist. I broke the bowl last time I changed mine using only the socket. Now mine only gets changed once a year since it's my tow vehicle and not my daily driver. I think the o ring got a little sticky due to the extended duration of filter changed. Sounds like some guys have bought spare bowls to keep in their tool boxes for a "just in case" moment.
If you plan to just use that socket, you better gave a spare assembly on hand.
a strap wrench around the entire casing is the only way to ensure that you do not cracked that plastic cover.
