A "Lisle" brand socket at an auto parts store is MUCH cheaper. It works better on 4x4's also since it is not as long.
Absolutely! And the other plus is its 3/8" drive rather than 1/2" found on a normal socket of that size, so you can use ratchets and extensions that work better in confined areas.
