I picked up a 32mm socket for a couple of bucks at Harbor Freight.
Figured it didn't need to be a name brand high strength socket since it will be used on plastic.
my 2012 f250 has 32mm. i read to open the bleed screw just a hair while spinning the filter body.
You resurrected an old thread but when you go to change the lower filter in the DFCM aka diesel fuel conditioning module as Ford calls it, you need to loosen it 3 full turns to break the suction before you open the drain plug or else it'll keep pulling fuel out the tank because it's still under pressure.
