cv swap
cv swap
got the 64 f100 truck and going to pick up a 03 cv this Friday
was going to fallow Texasknowhow utube series to put it put the cradle in the truck I have better cutting tools than him tho no sawzall I hope heheh
what do u guys think of his build?? be for I get started also ,if u need anything from the 03cv let me know and pay shipping and its yours
thanks mike
thanks mike
Unbolt the 2 engine perches, and when you swap in the CV sub frame. You will notice 2 vertical mounting points.
Cut 2 squares of 1/4 plate steel to match the vertical mounts. Drill a hole, and tack in a 7/16 bolt to bolt to the vertical mounts off the CV sub frame.
Bolt down to the CV sub frame. Now measure the engine stands, and cut down factory stands. Tack to the 1/4 plate you just bolted to the sub frame. Remove bolts, and fully weld. Grind as desired for finished look.
Measure once
Cut twice
So you have a template of what not to do.
Measure once
Cut twice
fordsrgrt
04-22-2018 07:50 PM
jniolon
16
03-29-2012 07:56 PM
Greywolf
04-24-2002 06:19 PM
