Wiring harness part #
Post #3: C7TZ-14289-Y was replaced by D4TZ-14289-P as was D0TZ-14289-K and a gazillion other part numbers.
FoMoCo is in-famous for replacing/updating 10's of 1000's parts numbers EVERY YEAR!
It was a PITA back then and still is today. And the thing is, these replaced part numbers disappeared from updated parts catalogs, so there was no references.
http://i.ebayimg.com/images/g/ReEAAO...KT/s-l1600.jpg
Bill, here is the picture of what the seller says is for my 69 f-250. It has at least 3 extra connectors that my original doesn't have. Mine has the 3 connectors for the coil, temp and oil senders and on the other end it has one 3 terminal male/female connector. That's it.
That sounds like a D4AZ14289R. Which also replaced a gazzilion other part numbers because it was rather long. You might call these guys and have them eyeball and measure their D4AZ14289R. I'll betcha it will work.
Nos Parts Source *Fo
913.220.5746
68/69 F & T850/1000.....401,477,534 gas engines....with transistorized ignition.
tbruz
05-12-2016 04:26 PM
GIO23
02-10-2010 09:35 AM
