NOS wiring harness.
Forsaking that, are there any NOS wiring harnesses available for this truck (NumberDummy??) (I realize this is a long shot)
Looking forward to the collective wisdom on this forum!
Forsaking that, are there any NOS wiring harnesses available for this truck?
223/262/292 Applications: 1961/63 F100/350 ~ 1961/62 F500/600 ~ 1963 F500/600 before serial number 430,001.
1961/62 F700/750 292/302/332.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
Note: inre to NOS on ebay: There are TWO different engine gauge feed wiring harnesses for 1961/63. I-6 is different than 292.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5646.
Note: There are TWO different engine gauge feed wiring harnesses for 1961/63. I-6 is different than 292.
This is only the dash wiring harness, but it pokes out of the firewall so other harnesses can connect to it.
Now if all those ford electrical connectors weren't obsolete...
I bought the $8.00 wiring diagram book for my year, and studied that. Then I found a great all-in-one wiring diagram online and printed it out poster-size and went to work tracking down all the issues in my own rat's nest, cleaning up as I went.
Little by little as I got everything electrical working and cleaned up, I decided not to purchase a complete wiring kit. In retrospect, I would only do so if I planned to run a lot of extra power/circuits in the truck. I don't. Or maybe on a down to the frame project, I would do it. And I would probably use the one from American Auto Wire, although pricey. But that is my own preference and many people prefer other companies.
What I also did, was focus on the dash wiring cluster, as under the dash is where people tend to splice in stuff to the fuse box. Cleaned that up, made sense of the wiring, made sure colors matched stock (you can buy colored wire- ANY colored wire - of any length and gauge, online, pretty cheap). For instance, if I needed orange wire with a pink stripe 18 gauge - I could purchase 20 feet online, cheap).
Keep in mind that as soon as you invest in one of the after-market kits, in most cases you lose original color-coding of wires and are tied into whatever scheme the after-market manufacturer uses (often Chevy).
You didn't state what or if you have electrical issues other than being messy, but often people want to leap to replacing the entire wiring harness, when it's just a switch or another small cost part to bring things back to life.
Just my thoughts. Damn, I have to get back to work. I took some time off and spent much of it obsessing and working on my truck!
My point is I was able to locate everything I needed to restore my wiring back to stock and should have everything working again after a complete failure of engine firewall to dash meltdown/ corrosion/rust-fest.
eBay was the first place I looked and found everyone I needed. Lucky me?
I was thinking of the universal harness too, but didn't think I could pull it off. Lots easier to replace each section with brand new same-same sections.
I also found the 1963 Ford Truck F-100 - F-750 Wiring Diagram Manual for ~$13.
