2000 7.3 automatic suddenly went out of gear going about 30 mph wont go back into any gear, linkage checks fine, no slippage before problem, fluid seems normal good level not burnt no metal, out of ideas!
its 2wd , being an old c6 guy i'm not very familiar with electronic controls in transmissions but could there be an electrical issue that causes these symptoms?
You might see metal chunks in the pan, or you might not. Regardless of what you find in the pan the trans needs to come out and get torn down. You can't see any of what may have caused this problem by looking in the pan.
