NumberDummy you are awsome but I thank you misread his post. Can not find the switch on the truck I believe he meant. If he posted all the truck info looks like you could post prints of that also. My answer would be on the brake pedal. If it is not there I saw one on the hydraulic side on something before. 1960 Ford? Thank outside the box.
I guess it will be a hydraulic switch somewhere on brake pipe. Coincidentally or not the lights problem arose when the Master cylinder started leaking. We shall try again tomorrow.
Look on inside of frame rail just aft of the brake booster (which is outside). On my '63 F-850 there's a junction of hydraulic lines and the switch sits there fairly obviously.
That is where she is. I took the two wires off and joined them, no brake light. Took my mower battery and jumpers to the wires and she lit up...now just figuring(guessing) my next move
