Bat/alt gauge quit working
The reason Ford connected the choke to the stator wire is because there is no power unless the alternator is turning, while the coil has power any time the key is on.
If you went out to warm up your truck and it stalled while you were back inside having coffee the choke would be wide open.
It can't do this when connected to the white/black wire.
Ok I can just splice into stator wire then? That's easy enough. I guess measiring the voltage i have now would be wise. Just for info, when I ordeed the 1993 3.0 and 3.8 alternators they were the same size case. The 3.8 had longer mounting ears for the 8"+ mount. The 3.0 was the 7" again same size case 130amp. I also order that wiring pigtail from latemodelrestorations along with a 175 amp max fuse and fuse holder. I will delete those two small feed wires that lead to a fuseable link to the solenoid.
I don't know anything about a resistor in the exciter wire.
I've never installed one or seen one mentioned in any of the 3G swap threads.
I *DO* have a resistor wired across my charge indicator lamp, so the alternator will put out in the event the bulb burns out.
Incidentally, this is the reason you can't put an led in the charge warning socket. They don't pass enough current to get the alternator to turn on.
The 3g swap is so easy. Had to do some slight massaging of the alternator bracket but no problem. My power windows have never worked so good (although they still suck when its really cold). The gauge does read lower than before. I believe that is due to the pigtail resistor because a multi meter on the battery reveals 14.5 volts. I have not had any bat/alt gauge malfunctions since.
Kijutsu
1997 - 2003 F150
03-23-2007 08:07 PM
