Battery Gauge
Old Sep 3, 2004 | 02:57 PM
BassGuy's Avatar
BassGuy
Battery Gauge
Hooray! A new symptom...
Ok. My battery gauge dips while driving. It goes down to just over 1/4 for awhile, then comes back up to 1/2. Occasionally it'll spike to about 3/4 and drop back down.
There are no other symptoms. It starts every time, no weird noises... nothing.
Is this an indication of the alternator? Belt slippage? the battery itself?
Any ideas?
Old Sep 3, 2004 | 04:00 PM
Mike W's Avatar
Mike W
I would get a voltmeter even a cheap HF one and hook it up inside the cab. See if does the same thing or not.
Old Sep 3, 2004 | 05:15 PM
BassGuy's Avatar
BassGuy
I assume you mean on the leads of the gauge itself. That's not a bad idea.
But it only does it while driving, usually at highway speeds... Not when idling... at least, not so far.
Old Sep 3, 2004 | 09:09 PM
BassGuy's Avatar
BassGuy
Update:
Ok, I've got another symptom. This is the first time I've driven it at night since it started. When the battery gauge dips, the dash lights get dimmer.
So, I'm pretty sure that the gauge is reading correctly.
Now... ideas? Alternator? Battery cable? Belt? etc...
Old Sep 3, 2004 | 10:16 PM
89bII4x2's Avatar
89bII4x2
It sounds like you have a wire thats shorting out. It could be anything not nessacarily (sp) the lights.
Old Sep 4, 2004 | 04:39 AM
Mike W's Avatar
Mike W
Just connect the voltmeter at any 12 volt source like the cigarette lighter.
Old Sep 4, 2004 | 05:54 AM
Bob Ayers's Avatar
Bob Ayers
Intermittent alternator output is usually due to worn brushes.....
Old Sep 4, 2004 | 02:58 PM
pawpaw's Avatar
pawpaw
Well I'd run this puppy by your favorite autoparts store, like Advance Auto, AutoZone, ect & let them use their portable machine to do a no cost, LOAD test of the entire vehicle electrical system, right in the vehicle.
This equiptment can load test the battery, alternator & regulator. If any component is weak or faulty, it'll likely sniff it out.
Could be anything from a shorting battery cell, to defective regulator, to worn alternator slip~ring brushes as Bob Ayers suggested, to damaged insulation on a wire being blown about at speed & grounding out, to.... well you get the idea.
Get those basic electrical system components LOAD checked & see if it'll point toward something specific.
Let us know what you find.
Old Sep 5, 2004 | 09:15 AM
BassGuy's Avatar
BassGuy
Thanks! I had already taken it to Advance to get that test done, but their mobile tester was down, so I was only able to test the battery... Which is good (I was hoping it was bad).
I'm gonna take it to another one today and have the entire test done.
I'll be sure to post the results.
Old Sep 6, 2004 | 10:47 PM
BassGuy's Avatar
BassGuy
Ok, it was the alternator. I guess it was just dying slowly.
Thanks for all the input.
Old Sep 6, 2004 | 11:05 PM
pawpaw's Avatar
pawpaw
Ok BassGuy, Bob Ayers called that one right on.
How did you determine for shure it was the alternator?? Did you find a Advance with some operating portable test equipt??
Get that puppy fixed & back on the road to the lake, cause the big ones are gettin away while your tinkering with the Ranger.
Gotta wait for the storms to abate, so I can get back to my bass fishing on my home waters. I drag a Tracker 175 with the Ranger. Good fishing. pawpaw
Old Sep 7, 2004 | 01:28 PM
BassGuy's Avatar
BassGuy
Well, it died during the charging test at Advance. So... yeah, alternator. Works like a charm now. I'd just never seen an alternator die so slowly before, so I was a bit confused.
As for the fish... Wrong "Bass". I'm a bassist, as in bass guitar.
Old Sep 7, 2004 | 04:31 PM
lala's Avatar
lala
BassGuy:
definiately sounds like the brushes were on their last legs. As they wear, their pushed with springs against the rotor, till there's nothing left. Then, no alternator juice.
lala
Old Sep 7, 2004 | 08:52 PM
BassGuy's Avatar
BassGuy
Ok, now I understand. The brushes are just like electrical connection points, yeah? So they just wore out. Yeah, makes perfect sense... Thanks.
ericl78
Jun 2, 2014 06:42 AM
bigpimpin
Dec 1, 2013 12:02 AM
harrisford
Dec 23, 2012 09:29 AM
mlee52554
2004 - 2008 F150
Oct 14, 2008 10:45 PM
sivart
1978 - 1996 Big Bronco
Apr 24, 2006 04:12 PM
