1994 f150 4.9l v6
Welcome to FTE.
Your 4.9 is an in-line, not a V.
OBD I codes:
I'm too lazy to post the links but the links are in these threads, which will help set your mind straight and at ease. You will see throwing parts is not the way, and you will rest easy knowing you are not alone:
https://www.ford-trucks.com/forums/1...s-changed.html
https://www.ford-trucks.com/forums/1...-computer.html
OBD I codes:
Best I can do:
Ford OBD I Diagnostic Trouble Codes¦ Retrieve and Repair
Fuel pump should be fairly quiet. OEM pump?
Best I can do:
If your exhaust isn't the kind that will make your neighbors angry if you rev it up at 12AM the OEM pump in a metal tank will be louder than the rest of the truck at idle (if you're standing beside or behind the truck with the hood closed, otherwise the fan is the dominant noise source).
Encho
1978 - 1996 Big Bronco
02-04-2017 01:05 PM
Breanon
03-12-2011 03:03 PM
