FIPL Help?!? Getting codes 23 & 41
Old Mar 11, 2011 | 07:09 PM
Breanon's Avatar
Breanon
Question FIPL Help?!? Getting codes 23 & 41
Hi there-
I took my 1992 Ford F150 (V8-302 5.0L) to a shop near my house to get the diagnostic codes run on my truck. It came back with the two codes of 23 & 41.
My truck has been idling VERY high, when it's in neutral or when I push the clutch in to change gears. Then the other day, as I was driving around town -- it died on me about 4 times.
Can anyone tell me what the two codes mean and/or how to go about fixing them? I know that it might have to do with a FIPL or something?
Any information would help... thanks!!
Old Mar 11, 2011 | 07:35 PM
rla2005's Avatar
rla2005
Ford started the transition from 2 to 3 digit codes in 1991 are you sure you have 2 digit codes? How did the shop pull the codes for you?
Second question, what is a FIPL?
Old Mar 11, 2011 | 07:40 PM
Breanon's Avatar
Breanon
Well... I paid about $100 a few weeks ago at a Firestone shop for them to do a diagnosis on my truck because I was having trouble with it. They fixed the primary problem that I brought it in for that day, but there was the idling issue that they didn't fix. I took it back today, and asked them to pull the codes again so that a friend of mine can work on it for me (as I can't afford to pay their labor again). The mechanic came back with a piece of paper and the following was written on it:
2 codes
-23 (TP/FIPL sensor out of range)
- 41 (EGO not switching)
I googled what a FIPL was, and I guess its a fuel injection pump lever?
Old Mar 12, 2011 | 01:01 PM
subford's Avatar
subford
FIPL is only on Diesel Trucks.
It mounts on the side of the injection pump and provides information to the Transmission control.
You have a TP Sensor or shorten to TPS, TPS = Throttle Position Sensor.
If you have a Standard Transmission, an AOD or a C6 then yes you would have 2 digit codes.
The three digit codes were only for the E4OD in 1992.
I would check out the TPS first.
Here is a link to some information on the TP sensor.
Ford Fuel Injection » Throttle Position Sensor (TPS)
Old Mar 12, 2011 | 03:03 PM
Breanon's Avatar
Breanon
Thank you so much Bill! That clears things up!
Beast of Busco
Apr 17, 2017 08:44 PM
dutyhole
Mar 3, 2017 01:09 PM
awolin
Jan 16, 2017 04:26 PM
rterril02
Apr 17, 2016 10:42 AM
Gman75
Jun 17, 2009 01:01 PM
