Just What You Want to See... Another '53 Build
I've wanted one of these old trucks for along time but life and other interests always seem to get in the way.. I've recently retired and need something to keep me busy, so Momma gave the green light and I started shopping.
I came across this '53 fairly close to home. Probably payed a little to much for it but I wanted an original Flathead truck and when I found a '53 I had to go for it.
Specs are: 1953, F100, 239 Flathead w/EAB heads, 3 on the tree and a 3.92 rear.
It's all there and pretty solid. Most rust is in the driver side forward cab mount area. Frame is excellent.
When I found it it was sitting in a garage in central Michigan and had been there about 4 years. Owner advertised that it ran and drove. Upon arrival I found it sitting in a corner covered with dust, no battery and at least 4 year old gas. When we tried to push it out to get a look at it, the right rear brake was locked solid. Had enough help to slide it across the dirt covered floor. The situation gave me a lot of bargaining power (not the least of which was false advertising). In the end he took less than he wanted and I paid a little more than I wanted, so it worked out. The plan is to keep it stock and original.
As I found it...
New Battery, New Fuel Pump, clean gas tank and new fuel lines, fresh oil in engine, trans and rear end. Also cleaned up and bled all the brakes... Runs extremely well now and makes its way down the road but a long way to go...
As I found it...
Welcome. You have a fine looking starter there. You will have fun and learn so much on this forum the guys here are friendly and very knowledgeable. I know it's pretty late at night for the old timers but I'm old too and I don't worry about it. I have always like the 53's, but they were modern when I was a kid.
Wow! What a find. It looks straight without any rust holes or big dents. And you got it running and stopping, great!
Welcome to FTE and the world of old Ford trucks! FTE is the best Ford Truck Forum on the World Wide Web.
Thanks for the pics and keep them coming. Some under the hood and the inside of the cab would be liked!
Thanks Guys!! This old truck has already been more fun than I imagined. Big regret is that my Dad is not around to help. He was a Ford mechanic when this was new and it would be great fun to call him and ask "how does this work?"
(not that anything is that complicated).
The seller failed to mention that it was now converted to 12 volt. Glad I noticed one of the headlights said 12V on it before I bought a battery.. The original fuel pump had it's lines cut and left in place. An electric fuel pump was added. I queried him on that and he said the guy he got it from had put that on and it worked fine for the 10 years he owned the truck. It too was 12V. Funny thing is that when I powered it up, it flooded the Carb. Did a little research and found it was an 8 LB pump. I seriously doubt the truck ever ran with that pump installed. It was easily remedied with new mechanical pump.
Currently:
1) trouble shooting Turn Signal/Brake lights (think I have a handle on that, with much help searching these forums)
2) Trying to figure out what to do about tires. Front ones are pretty bad and backs "look" ok.. would like to just replace the fronts for now but it seems 600x16s are pretty expensive and I don't want to throw the money away if I am considering a different wheel and tire combo. Just trying to get by until the snow flies and I start the complete tear down...
Currently:
Welcome, new here myself and with a 53. Yours is in great condition it appears, as with anything there is still plenty to fix or customize to you.
Looking forward to your updates!
What is the original paint code? With the red rims and red showing through the black wonder if it had been painted.
Hi Shawn, the original paint code was Black. The red your seeing on the box is actually a primer I think.. I don't think this is the original box.
Story is that the truck was gas station vehicle the better part of it's life in Kentucky. Hard to read, but on the door is painted "Perry's / 24 Hour Service". The station decal was removed and the sign painted over for some reason... I took some fine steel wool and buffed it till the white came through...
Nice
Hanger;
Nice looking project. You've got a good base to work from. What are your plans, keep it as close to stock as you can?
I'm sure you'll uncover some more surprises along the way, but that's what this hobby is all about. Good luck with it, and make sure you keep the pictures coming.
Tom
Tom
Getting "Henry" (my wife named the truck) road-able so I can get a few miles on it before the snow flies and the full resto begins...
Decided we need to go with a wider wheel and a radial tire.. was wondering what you guys like in a stock looking wheel/tire comb that will fit well and look good?
I see a lot of trucks with a stock looking steel, painted wheel with chrome trim rings a stock small hub caps that we really like but I've seen no reference to diameter and width..thinking 15x6 on the front and 15/7 on the back.
Any opinions?
Any opinions?
Received 1,353 Likes
on
