1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2000 F250 Mirror upgrade
Old 10-08-2016, 08:36 PM
norcal707's Avatar
norcal707
norcal707 is offline
i'm looking to upgrade my mirrors. A friend told me to get the 08+ mirrors but I can't find anywhere online that says they will work. I'm hopefully going to be purchasing on Amazon but not sure which ones to get. When I pull up the 08+ they say "Fits Ford 2008-2015 2008 2009 2010 2011 2012 2013 2014 2015 F250 F350 F450 F550 Super Duty"
Ive got the 2000 F250 V10
help
Old 10-08-2016, 08:38 PM
CharlyG's Avatar
CharlyG
CharlyG is offline
The Tech Folder for the Excursion has a write up
https://www.ford-trucks.com/forums/1...l#post15271495
Old 10-08-2016, 10:18 PM
norcal707's Avatar
norcal707
thanks!
Old 10-09-2016, 01:23 AM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
Here you go
They will work.
Old 10-09-2016, 01:25 AM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
1A Auto will sell you a kit that has the correct adapters to make later model mirrors fit earlier wiring harness.
This guy will probably know
@1ATony
Old 10-09-2016, 02:11 AM
hwybee22's Avatar
hwybee22
hwybee22 is offline
@1ATony
This is the route I used and I'm very happy.
Old 10-11-2016, 12:04 PM
1Aauto's Avatar
1Aauto
1Aauto is offline
Former Vendor
Thanks guys; if you need any help selecting tow mirrors for your vehicle, I can help you out.
Tony
Old 10-11-2016, 07:37 PM
ligito's Avatar
ligito
ligito is offline
Does anyone make a switch with a timer, for the heated mirrors, that will fit in a Carling Contura switch panel?
Old 10-11-2016, 07:42 PM
CharlyG's Avatar
CharlyG
CharlyG is offline
what is this language you are speaking?
Old 10-11-2016, 08:49 PM
FordBlueHeart's Avatar
FordBlueHeart
FordBlueHeart is offline
I used a lighted rocker switch. This way it's only on when I want it on. The light reminds me to shut it off.
Old 10-12-2016, 09:38 PM
ligito's Avatar
ligito
ligito is offline
That is what I'm using but I would rather have a defroster switch that fits my Carling panel. I have some defroster switches from the junk yard but none of them fit my panel and I want some uniformity.
Old 10-13-2016, 04:03 PM
FordBlueHeart
You want a "defroster" switch because of it being timed? If that isn't the most important thing, can't you order a new switch with whatever you want on it?
Old 10-13-2016, 08:03 PM
ligito's Avatar
ligito
ligito is offline
I want it timed and I want it to fit in a panel of my choice, rather than having another size and shaped odd hole in my dash.
Old 10-14-2016, 04:18 AM
Shovelheadrob's Avatar
Shovelheadrob
Shovelheadrob is offline
AFAIK most defroster switches just send a signal to a timer relay via a momentary on contact, just get a switch that fits & a relay.
Old 10-14-2016, 12:22 PM
ligito's Avatar
ligito
ligito is offline
I can't find a relay that has a timer, that will shut off, after ten minutes.
Quick Reply: 2000 F250 Mirror upgrade
