Improved front turn signals
The front turn signals on my 55 F350 weren't very bright. I thought the PO had put 12 volts bulbs in since I had found 12 volts bulbs in many of my marker lights. I put a 12 volt bulb in one and it was much dimmer. I bought 2 new 6 volt bulbs since I didn't know how old the bulbs were.
The best improvement was to paint the rear insert with shiny reflective metallic aluminum paint. I used Super Glue to reattach two broken pieces of the plastic lens.
I put them back together and the brightness was noticeably better.
Do you realize how hard it is not take a picture of a flashing light with your cell phone! It took me four tried to capture it.
Abe, how did you get that metal part out of there? I have 2 of those lights that I need to replace the carriage bolt/stud that attaches them to the fender (not to mention I need to drill through that stud! Mine look identical to yours but I can't get that inner part out. Maybe it's just corroded on really good
thanks Abe, as easy that might have seemed mine were so stuck together that I wasn't sure and didn't want to break them. Well tonight I got them off and cleaned/fixed. Keep in mind I'm 12v but what I did is using the original single socket I used a dual filament bulb and the contact pad is big enough to contact both points on the bulb so you want to talk about BRIGHT, they work like a top. Not sure if there is a 6v double bulb but if so might be worth a try?
PaysonPSD
66
12-30-2016 08:09 AM
PapaJoes52
07-03-2010 11:28 PM
