5.0L Coyote 5.0l Ford OHC Coyote engine for 2011+
2015+ truck and mustang 5.0 differences
Old 09-30-2016, 08:54 AM
kelwar's Avatar
kelwar
kelwar is offline
I have not seen anything on the second gen coyote about the difference between the truck and mustangs engines. Anyone know what's different in them and if the trucks got the boss 302 rods. Thinking about Doing a swap on one of my old trucks and truck engines seem to be easily obtainable conpared to mustang ones.
Old 10-05-2016, 05:41 PM
Turbo Dog's Avatar
Turbo Dog
Turbo Dog is offline
I don't know other than they are turned differently. You could go to a dealer and look up some parts for each engine and see if they are the same part number.
Old 10-10-2016, 08:19 AM
ubereal2's Avatar
ubereal2
ubereal2 is offline
What I've been told is that, the engine in the truck is tuned differently. So it is more of a truck engine so it has better torque. Besides, still has a 6.2 liter engine that they want to sell. Couldn't make the 5.0 whip it's larger displacement engine.
Unk Bob
Old 12-01-2016, 12:08 AM
Thorium's Avatar
Thorium
Thorium is offline
So a map from a mustang will work without issues if the truck is used more as a daily driver as opposed to a truck?
Old 12-05-2016, 06:58 AM
WXboy's Avatar
WXboy
WXboy is offline
The truck engine has different intake cams, different exhaust manifolds, oil cooler, and tuning which holds it's redline down. That's why the HP rating is lower.
The Mustang engine is allowed to rev higher to get that 430 HP number on paper, even though very few people are ever going to spend any time at 6,500+ RPM.
Old 12-08-2016, 10:20 PM
Thorium's Avatar
Thorium
Thorium is offline
That seems to be the case usually, cams, intake/exhaust and the tune, otherwise same.
Compression ratio is also another factor, not sure if this is the case here.
Old 12-09-2016, 08:35 AM
n2o's Avatar
n2o
n2o is offline
Pretty sure the truck is at 10.5:1 and mustang gt is 11:1.
Old 12-09-2016, 09:44 AM
mueckster's Avatar
mueckster
mueckster is offline
True. That is probably so they can add more timing on the truck engine at lower rpms to give it more torque in that area.
gt40racing
12-05-2010 07:51 PM
fordtruckman
General Automotive Discussion
04-17-2008 06:27 PM
onefordan
13
04-10-2006 04:55 AM
dcexplorer
09-29-2002 01:23 AM
shark4315
07-15-2001 06:54 PM
Quick Reply: 2015+ truck and mustang 5.0 differences
