05-10 rear axle
05-10 rear axle
So guys last year I swapped the front to the 08 axle. Now I plan on going to the rear axle. I cannot seem to find the info where it says If I can or cannot just use my old leaf spring brackets. I'm being told $250 for a section of frame with the brackets. Can anyone confirm if this is possible? I rather just reuse my old ones and save the $250 plus leg work to get the rivets out.
Couple other questions
Will a 5.4 3.73 axle work with my 04 6.0? I have the 08 6.4 3.73 up front
Will it bolt straight up? As in driveshaft to axle?
The single rear wheel trucks use the sterling 10.5 from 99' to present. Now granted in 2011 Ford changed the spring pack up and as well as few related things. brackets should be the same (as far a sknow) between your truck and the donor axle. For a longer wheelbase trucks with a two piece rear driveshaft they used a carrier bearing around the mid point.
I misunderstood you. If it were me I would leave the springs as is. I thought you just wanted to swap axles out. I don't really see bothering with the 11'up setup. They flipped some stuff, added fewer but thicker leaves, etc. I've driven both 03' truck and a 15' truck with the same configuration and gas engine. Didn't really notice much difference in the ride, just the tighter turning radius on the newer truck.
thatdude
01-27-2003 04:27 PM
