Anyone done this yet
Old Jul 13, 2011 | 10:47 PM
429unibody's Avatar
429unibody
How about using a rear diff set up from the 71 Country Squire in a slick,how does the width match up?
Old Jul 13, 2011 | 11:39 PM
Dugan5150's Avatar
Dugan5150
I did a little research just because I'm curious, and no one else has answered. I haven't yet found the width of the rear axle in a Country Squire or LTD, but the Slick's rear axle should measure 60" from axle flange to axle flange. I know that's only half the info you need, but I hope it helps.
Old Jul 13, 2011 | 11:47 PM
Dugan5150's Avatar
Dugan5150
Alright. According to this page :Rear End Widths
The axle width of a 64-71 Ford "Full Size" (trucks were listed separate) is 61"
Old Jul 13, 2011 | 11:58 PM
429unibody's Avatar
429unibody
I will be hauling the wagon home tomorrow so I'll measure it soon.
Old Jul 14, 2011 | 04:41 AM
jowilker's Avatar
jowilker
If they are both 28 spline 9in rears, you should be able to swap the center chunk for a different ratio if that is what you are trying to achieve.
I think the mount points are different between the vehicles.
John
Old Jul 14, 2011 | 07:48 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1971 LTD Country Squire could have 3 different rear axles.
1) WER 8.7 integral.
2) 9" with R/L specific 28 spline axleshafts.
3) 9" w/a 9 3/8" ring gear.
Even though classified as a 9, with a 9 3/8" ring gear, only five internal parts are the same: Housing gasket, pinion seal, (1) pinion bearing and race, pilot bearing retainer.
Everything else is different!
1965 and later Galaxie/LTD's have rear coil springs, trailing arms and a track bar.
Old Jul 14, 2011 | 08:46 AM
429unibody's Avatar
429unibody
1965 and later Galaxie/LTD's have rear coil springs, trailing arms and a track bar.This is the set up in the car I'm getting. Is the width comparable to use in my 61? It would be fairly easy to make mounts to use all the stock arms from the wagon and just make a bracket for air bags
Old Jul 14, 2011 | 09:02 AM
NumberDummy
That's a 1971 LTD/Country Squire, has the "Bunkie" Knudsen snout on it.
If it didn't have rear coils, trailing arms, track bar, it would be a '71 Torino Country Squire.
Don't think you can use a Passenger Car 9 in an F100. Too many variations.
And, if it has a 9 3/8 incher, you do not want it. Most internal parts are different, tis difficult to find replacement parts.
If it has the WER 8.7 integral, it's totally different than either 9.
Old Jul 14, 2011 | 10:20 PM
429unibody's Avatar
429unibody
ND it does have the rear coils, I got the motor running today ,it does not smoke at all, forward gear does not work, I could cut off all the mounting brackets and weld them to a 9 inch,yes? Lots of work but I think it would be a cool install! I want to build my 61 on a so called budget build.
Old Jul 15, 2011 | 05:26 AM
jowilker's Avatar
jowilker
429, It does not have the same 5 on 5.5" wheel bolt pattern. You would have to run 2 sets of wheels, no rotating.
John
Old Jul 15, 2011 | 05:33 AM
NumberDummy
Good point John, I hadn't thought about that glaring fact.
1971 LTD station wagon: 5 lug, 15" x 6.50" wheels on a 4.50" bolt circle.
Old Jul 15, 2011 | 05:39 AM
jowilker's Avatar
jowilker
Mr. Wilson, I know I am not the brightest bulb in the room, but I try to shed a little light.
John
Old Jul 15, 2011 | 07:16 AM
429unibody's Avatar
429unibody
John
Ahhh Sensai you forgot that I already did the Aerostar install
Plus I'll be running different size wheels and tires left to right for turning left mostly...lol
On a serious note I want a street truck look so I'll have wider tires on the rear!
Old Jul 15, 2011 | 07:22 AM
429unibody's Avatar
429unibody
Is that the same bolt pattern as the Aerostar?
Old Jul 15, 2011 | 07:24 AM
429unibody's Avatar
429unibody
I see there are no grills for the LTD for sale on E-Bay ,maybe I might get lucky and get a good price for mine.
