Won't start off key only pull start
#33
#35
#36
Here is the link to my recent low oil pressure issue:
This shows how far off base you can get without a means to scan it and see what is really happening
https://www.ford-trucks.com/forums/1...ont-start.html
#37
#38
Alright so I have a reader I went to read the codes but it just said can read codes no communication but there are 124 codes. So I thought it might be my code reader so I took it to a shop and I had the engine running and when we plug it in the engine kinda studered the. We press read codes and the engine died and shut off still I have 124 unreadable code. Could this be PCM
#39
It's not the PCM. In both cases, it's the device. A generic OBD-II device won't communicate with our trucks, at least not to obtain diagnostic codes. A typical indicator of a device that doesn't "know" the OBS PSD's not-really-OBD-II protocol is that it kills the engine when you try to obtain codes. Get to a shop that you know has worked on our generation of truck. Other option is one of the DIY options for reading codes (AutoEnginuity, AeroForce, etc); there are tons of threads on the topic.
#41
what reader did you get?
