Decoding a warranty plate
Hello,
I am looking at getting an old what looks to be a n series ford truck maybe a '64? I couldnt find a vin but found a warranty number. Would anyone be able to decode it for me?
Warranty Number:
*N60au543943*
WB:
144
Color:
J
Model:
N602
Body:
181A
Trans:
A
axle:
64
D.O.S.
43
Warranty Number:
*N60au543943*
WB:
144
Color:
J
Model:
N602
Body:
181A
Trans:
A
axle:
64
D.O.S.
43
I am looking at getting an old what looks to be a N series Ford truck maybe a '64? I couldn't find a VIN but found a Warranty Number. Would anyone be able to decode it for me?
Warranty Number: N60AU543943 // WB: 144 / COLOR: J / MODEL: N602 / BODY: 181A / TRANS: A / AXLE: 64 / MAX GVWR LBS: 20000 / CERT NET HP: Omitted / RPM: Omitted / DSO: 43
The Warranty Number is the VIN, but the VIN on the Warranty Plate was not used by DMV's to register vehicles, as the plate was too EZ to change.
Compare the Warranty Number to the VIN on the registration and/or title to see if they match.
People replaced damaged left doors with used doors. 99.9% of the time, they failed to install the original Warranty Plates on the replaced doors.
N60 = N600 (gas).
A = 330 2V Medium Duty FT engine.
U = Louisville KY Assembly Plant.
543943 = 1964, assembled May 1964.
144" Wheelbase.
J = Rangoon Red.
N602 = N600 (gas) .. 20,000 lbs. GVWR
181: 1 = Light Gray Crush Vinyl & Light Gray Rib Vinyl / 81 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
64 = Timken model F106 Single Speed Rear Axle / 6.80-1 / 15,000 lbs. Rear Axle Capacity.
20,000 lbs. Gross Vehicle Weight Rating.
43 = Milwaukee WI Ford District Sales Office, where the original selling dealer ordered the truck from.
GamecockFord
05-03-2010 10:50 AM
