1966 F600 tag decode
F60 = F600.
B = 300 1V I-6.
C = Oakville Ontario Canada Truck Assembly Plant.
776550 = 1966, assembled November 1965.
174" Wheelbase.
B = Caribbean Turquoise.
F602 = F600 .. 20,000 lbs. GVWR
481: 4 = Medium Beige Crush Vinyl & Medium Beige Wicker Pattern Vinyl // 81 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
F8C: F8 = Eaton model 13802 Two Speed Rear Axle / 6.33/8.81 / 15,000 lbs. Rear Axle Capacity // C = Ford Rockwell/Timken Front Axle with 6,000 lbs. Capacity.
20,000 lbs. Gross Vehicle Weight Rating.
150 net HP @ 3,600 RPM
36 = Louisville KY Ford District Sales Office, where the original selling dealer ordered the truck from.
B = 300 1V I-6.
174" Wheelbase.
I'll give it a go using my truck manual (CD).
F60 F600
B 300 cu in
C assembled in canada
174 wheel base
B ext paint?
F602 model
4 beige vinyl trim package
81 standard cab
A 4 speed new process transmission
F8C eaton rear axle?
20000 GVW
150 HP
3600 RPM
36 ???
Hopefully someone can fill in the "?" and correct any mistakes.
john
F60 F600
B 300 cu in
174 wheel base
B ext paint?
F602 model
81 standard cab
20000 GVW
150 HP
3600 RPM
36 ???
john
