Opionions wanted
Old 09-21-2016, 07:24 AM
osu711's Avatar
osu711
osu711 is offline
Opionions wanted
Hello all, my '96 is starting to leak fuel out of the valley and ive determined the fuel bowl needs rebuilding (pump was changed shortly before I got the truck at roughly 236k, at 287k now)
Now here is my question, would it be worth just buying a rebuilt bowl or rebuilding my old one?
I want to rebuild my ipr, hoses and everything else associated with bowl as well because I really don't want to pull it back off again. a new assembly runs roughly 300 bucks and I will have all new sensors, o rings etc.
Old 09-21-2016, 08:38 AM
lee00's Avatar
lee00
lee00 is offline
One word...E-Fuel...
If I had the cash I would have done it myself...
Old 09-21-2016, 10:01 AM
knottyrope's Avatar
knottyrope
knottyrope is offline
rebuild is cheaper than buying new. I rebuilt mine and replaced pump too since it was 62 bucks on ebay.
I got all my bowl parts from 1994-1997 'OBS' 7.3L Powerstroke
I did injector orings since my fuel filter was dark.
turbo inlet rubber was split on mine and the other boots had cracks
Your Order Contains:
  • 1 x 7.3L Fuel Filter 94-98
  • 1 x Complete OBS Fuel Bowl Reseal Kit
    (Type of Drain Valve O-rings: Fluorosilicone Drain Valve Orings)
  • 1 x Fuel Bowl Regulator Bypass Hose 1994-1995
  • 1 x Fuel Pump Hoses
  • 1 x Fuel Pump Upper Hose
  • 1 x Banjo Bolt Gasket Set
  • 1 x IPR Complete Re-Seal kit
  • 1 x Turbo / Pedestal O-rings
  • 1 x Garrett Compressor Housing Outlet O-ring 94.5-Early 99
  • 9 x Alliant Injector O-rings
  • 1 x Motorcraft Cam Position Sensor CPS 94-03
  • 1 x Riffraff Diesel 94-97 Turbo Intake and Y Boot Kit
Old 09-21-2016, 10:10 AM
lee00's Avatar
lee00
lee00 is offline
Very true...but not having to work on or have leaks from that weak point = priceless...
Old 09-21-2016, 06:40 PM
carltonwebb's Avatar
carltonwebb
carltonwebb is offline
what is efuel
Old 09-21-2016, 07:02 PM
Jarrett Campbell's Avatar
Jarrett Campbell
Jarrett Campbell is offline
Originally Posted by carltonwebb
what is efuel
E fuel is converting the stock mechanical fuel pump and fuel filter in the engine valley to an electric fuel pump and filters on the frame rails (generally)
There are several kits out there or you could piece together your own. Diy is typically more time consuming but you could save some cash
Old 09-21-2016, 07:26 PM
fordman67's Avatar
fordman67
fordman67 is offline
Otherwise known as the complete solution... E-fuel...
67camaro
04-09-2018 09:10 AM
BigRick1979
111
06-25-2015 06:32 AM
BieselDiesel
12-28-2012 09:02 AM
ron's power stroke
20
12-08-2011 02:11 PM
jimwilsonmasonry
07-14-2008 04:18 PM
Quick Reply: Opionions wanted
