Wiring a 12v power to up fitter switches
The 99 should have some blunt cut pass thru wires. They are in a similar position inside the cab and they come out above and to the outside of the master cylinder under the hood. It saves you the process of running a wire through the firewall, but you still need to hook up power and your own switch.
Deeman194,
Just a word of caution on using the Upfitter Switches/Wires. Be aware the switches are rated at 30/15/10 amps depending on which one you use.
If you placed an inline fuse with the camera supply wire rated for it's wiring that is good. If not, you might want to consider doing that. I suspect the supply wires for the camera are fairly small.
If, and I would agree it probably is a big if, there would develop a short in the camera (or camera wire), the wires could burn and cause a fire before the fuse for the Upfitter Relay would blow. Wires burning up under the dash is no fun. I have seen it happen.
On my truck, Upfitter 3 is rated the lowest at 10 amps. If nothing else, you may want to consider putting the camera on that switch.
Good luck with your camera.
Tom
Tom
ctvanover
04-07-2013 06:41 PM
1968stepside
50
03-08-2004 12:41 PM
