1966 - 1977 Early Broncos
1974 Fuel level sensor
Old 09-06-2016, 03:50 PM
acoultha's Avatar
acoultha
acoultha is offline
My '74 has a fairly standard plastic tank but the gauge is a Pro-Comp. I had to replace the sender a while back and picked up a standard sender from Jeff's Graveyard, but it doesn't work with the gauge. Playing with a variable resistor I find that the gauge wants to get 33 ohms for empty and 5 ohms for full.
I cannot find any senders that provide this - any suggestions?
Old 09-07-2016, 02:42 PM
dclack's Avatar
dclack
dclack is offline
Are you talking about the side tank? Are you sure you got a sender for the side tank and not a rear tank?
Old 09-07-2016, 03:40 PM
chrlsful's Avatar
chrlsful
chrlsful is offline
gotta match up 1st
no ele guy here but - ck continuity 1st then find if they sold U one that zeros out on the same (whatts or volts or sompin like dat)
sorry
But they gotta B compatable frm jump (the beginning).
Old 09-07-2016, 08:28 PM
acoultha's Avatar
acoultha
acoultha is offline
This is the rear tank.
Old 09-07-2016, 11:24 PM
chrlsful's Avatar
chrlsful
chrlsful is offline
ele trouble shootin
1) dash guage'n sender hafta match (in terms of ohms).
or
2) sometimes the ele part on back of the guage (dash) is 'gone out'.
IVR (instrument volt regulator) it's a seperate lill box (different prt than the guage itself)
it's all gotta be well grounded...
Old 09-08-2016, 09:27 AM
dclack's Avatar
dclack
dclack is offline
Sounds like you might have the wrong sender. I'm guessing you got one for a '74 but it sounds like you have a '77 rear tank; '77 was the only year to have a plastic rear tank.
Old 09-08-2016, 07:56 PM
chrlsful's Avatar
chrlsful
chrlsful is offline
rear tank sending unit needs 2 match the dash gauge
this 1 yr only sending unit has become avail, altho still a lill rare. Is Jeff the only 1 2 have it?
I purchased 1 a lill while ago. The guy who put it in did so that now it fell inside. Gotta start over but will use the same sender. It wuz registering on the dash.
Old 09-08-2016, 08:06 PM
dclack's Avatar
dclack
dclack is offline
Old 10-08-2016, 11:27 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
9275: Scroll down to 1973/79 Bronco fuel tank sending units.
With fuel vapor return tubes: Evaporative Emission system (unleaded fuel non vented fuel cap).
Old 10-08-2016, 07:15 PM
chrlsful's Avatar
chrlsful
chrlsful is offline
fuel sender ('77 bronk)
THANKS
yet again, Bill!
Old 10-10-2016, 07:00 PM
chrlsful's Avatar
chrlsful
chrlsful is offline
"My '74 has a fairly standard plastic tank but the gauge is a Pro-Comp. I had to replace the sender…"
aint been around in awhile, musta given it to a mechanic?
a '74 is not typically rear tank plastic. an aux side tank may B.
Anything can happen w/a (human) 2 generation ol vehicle…
8^ )
Old 11-20-2016, 07:31 PM
acoultha's Avatar
acoultha
acoultha is offline
Yes, thank you, but this not a vapor return, this is a fuel injection system fuel return
Old 11-21-2016, 05:52 PM
chrlsful's Avatar
chrlsful
chrlsful is offline
1)tank or 2)return from motor
right below ur last post (this one too) will B 5 posts on what I thought U were asking. Now U seem bout da udder end'a the machine. Can't help, but again: CB's the site.
EDIT:
BTW-I saw, possibly ur vehicle, 4 sale on E-Bay. I might have seen aftrmrkt gages. As per earlier comment - the sender has 2 match the ohms of the gague. Possibly go back to the builder w/ur complaint (U should get ur money's worth).
on the other hand (still confused re Q): Today's EFIs often don't require a fuel return line as regulators, pumps, etc meet the need more precisely. Can't comment much as I don't wrk on that/don't have that system. Liking the mechanical better.
Last edited by chrlsful; 11-22-2016 at 07:44 AM. Reason: some of the mis-spellings
phil64
25
05-10-2019 07:29 AM
ump
1999 to 2016 Super Duty
10-08-2018 02:42 PM
AKHunter93
06-06-2015 06:47 PM
924x2150
18
08-29-2005 09:49 PM
Jullian
02-07-2005 07:24 PM
Quick Reply: 1974 Fuel level sensor
