Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
HVAC Blower issues......
Old 08-29-2016, 08:23 AM
MDSuperDuty's Avatar
MDSuperDuty
MDSuperDuty is offline
For some reason I've lost setting 1&2 for the blower speed for the HVAC. Only works on 3&4 which are the higher speeds.
Anyone have any input on why this may be?
2007 Escape XLT
Old 08-29-2016, 10:07 AM
tomw's Avatar
tomw
tomw is offline
Resistor 'pack' installed behind the glove box on the 'side' of the air plenum is used to put resistors in series or parallel and adjust rpm of blower motor. If one or more resistors die, the current won't flow & the blower motor won't motor. They are not expensive, and take a short time to install. Removal of the glove box, or emptying of contents, and springing the 'stop' to allow it to swing down should improve access to see and replace the resistor assembly.
tom
Old 08-29-2016, 01:21 PM
MDSuperDuty
tom
Ok great I will look into that. Was weird how it would only work on settings 3&4 and NOT on 1&2.
Old 08-29-2016, 01:51 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Yeah, it is weird. Usually, a resistor pack failure will take out speeds 1, 2 & 3, not just 1 & 2. For 1 & 2 to go out would require two separate but closely related failures.
Check the connector at the switch for melting, as well as the one on the resistor pack before buying any parts. Melted connectors at either end can give some unexpected results.
Old 08-29-2016, 02:11 PM
MDSuperDuty
Don't worry. I don't buy parts unless I know I found an issue.
Old 11-19-2017, 01:19 PM
MDSuperDuty
Finally looking into this but have no clue where im looking. Maybe these images will help someone point it out to me.
Old 11-19-2017, 04:22 PM
MDSuperDuty
Found it.......
Old 11-19-2017, 07:26 PM
5_labsownus's Avatar
5_labsownus
5_labsownus is offline
Received 1,563 Likes on 1,456 Posts
Glad you found it and the "blow motor resister" is the common reason to loose 1 or more settings in all makes and models.
Rod
Old 11-22-2017, 01:51 PM
MDSuperDuty
It was toast!
Old 11-22-2017, 05:52 PM
projectSHO89
A faulty resistor will NOT take out the highest speed....
GlenPxC
1999 to 2016 Super Duty
06-05-2019 08:43 PM
idipwr
12-20-2013 08:52 AM
Cal357
04-02-2011 11:15 AM
Cdy1
1997 - 2003 F150
01-29-2011 06:01 PM
wresleu
1983 - 2012 Ranger & B-Series
07-30-2004 06:46 AM
Quick Reply: HVAC Blower issues......
