Sponsored by: Auxito
replacing blower..
Old Jan 28, 2011 | 05:31 PM
Cdy1's Avatar
Cdy1
replacing blower..
anyone have any tips on replacing the blower motor in an 03? it is under the dash correct??
Old Jan 28, 2011 | 06:06 PM
steve(ill)'s Avatar
steve(ill)
are you sure its the blower and not a burnt out resistor block ?
Old Jan 28, 2011 | 06:08 PM
steve(ill)'s Avatar
steve(ill)
i have never taken a blower motor out of a F150... last blower i did was a chevy and it was behind the glove box... burn off motor lead due to bad resistor failure.
Old Jan 28, 2011 | 06:25 PM
Cdy1's Avatar
Cdy1
the resistor is only about 4 months old. the motor makes a little noise and trys to run when you kick under the glove box.
Old Jan 28, 2011 | 10:14 PM
steve(ill)'s Avatar
steve(ill)
lay on your back and look up behind the glove box. the chebby i worked on pipped out with 3 screws.. dont know about the F150. You might be able to spray the bearings or put a few drops of oil in it, and reuse.
Old Jan 29, 2011 | 06:01 PM
Cdy1's Avatar
Cdy1
replaced it.. took about an hour cause i had to run around through 2 junkyards to find one, got it for $20. easy job.
