Had bags for 9 years. Pump mine up to 50psi when hauling 5th wheel. 0 pressure when not. running 50psi empty(not loaded) is insane. No suspension at all.
never had a problem and love them. Bounce comes from crappy shocks.
You run 0 pressure when empty I thought that would destroy the bags..
It may well very by model. I know my Firestones in the past said to keep them no lower than 5 pounds, I think to reduce the likelihood of chafing the bag.
Yup. I run Zero. They will never bottom, or lose there shape. If they do then I have bigger issues !.
Think about it this way. ZERO psi. stroke it 1/2" x 5 " bore. Think about that, If I am at "0" pressure I go over a whoop bump, My bags will quickly pump them selves up just from compressing. Like I said. 9 years. Look as good as the day I put them on.
Leaving them at 5psi or 10 creates a stiffer ride. 5-10 PSI x 5" bore + 100 to 200pounds approx LBS. EACH
I can take pictures and send in if you want. Best install ever, worth the money.
