Another buzz test thread, but unexpected trouble code
Hey friends! It's good to be back here... this was always one of my favorite forums. I just picked up a 01' 7.3 with 268k. It was very cheap, I couldn't pass it up. I'm just dicking around with the truck and figured I'd pick your brain a bit.
It's pretty beat, and it does need some maintenance. Upon cold start the power is very low. So low that sometimes I can't make it out of my driveway if the front tire gets stuck near the curb. A couple points. Nearly no blowby from the oil cap test. No smoke at all from exhaust upon start up. Compression is assumed to be good. I unplugged EBPV harness to be sure and verified that it is indeed in the open position. That leads me to injectors. I did a cold engine buzz test and it's clear 1, 5, and 8 are weak:
My question to the forum is, the scanner gave code P1276. Indicating an issue with #6. This injector has a strong buzz both hot and cold, so I am puzzled by that? A few nights ago, the cylinder contribution test indicated 1 and 8 had a balance fault. This confirms the buzz test findings of weak 1 and 8. Today I took it for a long drive and now I get a balance fault on 8 and 5. So, I think it's pretty safe to say I need 3 injectors. The question is, do I need a 4th for #6 with that code?
Perdel Readings indicate that I do indeed need atleast 1, 5 and 8.
1) 1.8
2) 0.0
3) 0.1
4) 0.5
5) 2.3
6) 0.0
7) 0.0
8) 5.2
And just for fun, here's the hot engine buzz test:
You can clearly hear #5 wakes up and sounds normal when hot even though hot perdel readings are a little high. I'm assuming this is why the power so vastly improves. 1 and 8 are clearly still weak.
1) 1.8
2) 0.0
3) 0.1
4) 0.5
5) 2.3
6) 0.0
7) 0.0
8) 5.2
I haven't looked for those in Torque Pro yet - maybe one of these days/months/years.
rknight29
04-11-2017 05:45 PM
vlietracer64
01-26-2011 05:13 PM
kennedyford
07-07-2006 01:53 PM
