Problem with my 97 F350 crewcab
Old 09-10-2016, 08:55 PM
tanman722001's Avatar
tanman722001
tanman722001 is offline
Kevin. Yea it has the one light that stays on. I had to do the 4 number then the Bluetooth icon on Torque pro stop flashing put I had it hooked up for 3 or 4 mins and the car icon is still flashing and it won't scan the truck
  #32
Old 09-10-2016, 09:02 PM
tanman722001
Originally Posted by knottyrope
SAE J1850 PWM communication selected in bottom of profile?
I don't see where is it?
  #33
Old 09-11-2016, 02:55 PM
knottyrope's Avatar
knottyrope
knottyrope is offline
Click on gear ixo on lower left of main screen , then, then edit profile, scroll down to bottom.
  #34
Old 09-13-2016, 04:08 PM
tanman722001
Ok. I changed that still will not connect to ECM.Only light that comes on it the power light. I took it to my buddy that has scanned my truck before when the hpop went out. And his scanner will not connect to ECM neither. No matter what I try can get any scanner go connect to the ECM. Today I started and it ran great and shifted great until this afternoon then back to the same crap
  #35
Old 09-13-2016, 04:22 PM
madpogue's Avatar
madpogue
madpogue is offline
Have you tried connecting with your device, or your buddy's, when the truck is NOT having its running/shifting problems? Just a theory, but _maybe_ whatever is causing the truck to run and shift poorly is also causing an issue with connecting to it. So knock wood that it goes back to running right and try to connect again then. If there were codes stored, you should still be able to obtain them.
If it is something like this, the main connector to the PCM would be a place to look; make sure it's tight and dry.
  #36
Old 09-17-2016, 06:18 PM
tanman722001
Will give it a try if it ever goes back running and shifting right. Just for kicks I called a Ford dealer and talk to a guy in service department. Told him what my truck was doing and told him the year of my truck . He said oh ok 97's are bad at having computer problems. And said it will still run but not run right. So I make get one once I get some money saved up.
  #37
Old 09-18-2016, 12:29 PM
krifenbu's Avatar
krifenbu
krifenbu is offline
Have you checked to see if you have a performance chip on the PCM?
Kevin
  #38
Old 09-26-2016, 05:51 AM
tanman722001
Yea I looked don't see any chip. Just a black cover.
danalo01
10-22-2017 08:48 PM
sixkiller
08-06-2015 10:16 AM
Boonebird
04-28-2008 11:12 AM
PetalumaJoe
1999 to 2016 Super Duty
05-15-2006 02:29 PM
Boa1277
10-15-2005 02:25 PM
Quick Reply: Problem with my 97 F350 crewcab
