E40D Shift Issue
E40D Shift Issue
Still having problems with the transmission, but I have some more information regarding it now, to hopefully narrow down what is going on. I'm ordering an Aeroforce Interceptor to check the codes, but in the mean time, this is everything that is going on.
Truck is a 1997 OBS F350, 2WD, XLT, E40D, with 93K miles. Mostly stock, hasn't towed anything since the previous owner, however he was towing a 5th wheel and a boat in tandem.
- Hard shift in every gear (especially 1-2, and 3-4)
- No OD light blinking
- Erratic 3-4 shift (it usually shifts at 35MPH, 1500RPM, but a lot of times it'll shift at 2500RPM, or even 1300RPM.
- When manually switching the gears from 1-2-D, there aren't any problems, with the exception of a pretty bad vibration when getting off the gas in 1st.
I've already replaced the VSS with a Motorcraft part, replaced the EBP tube and sensor, and the neutral safety switch (it wouldn't start in park, only neutral, but thats fixed now). Fluid and filter are less than a year old, and still full.
I'm gonna check the pressure to make sure I'm getting the correct amount, but this has me completely stumped. Is there another sensor I should look at, or am I looking at a busted solenoid/accumulator, or is there something else going on?
I checked the connections this morning, and they were good. I did find something though. Attached to the same wiring harness that the neutral safety switch is on, there is some sort of round connector that has been capped. It's not plugged into anything. It runs along the driver's side of the transmission towards the back. Any idea what this is for?
It's taped directly into the harness, but i looked up a wiring harness for the 4x4 lights and it has the same plug. I'm 2wd so it doesn't matter
Interceptor came in today, so I pulled the codes. The only code I'm showing is P0603, and I had pulled the battery recently when I swapped the Neutral Safety Switch and the EBP Sensor. So there was nothing regarding the transmission. The fact that it works when manually shifting it makes me think whatever is going on is electrical, not mechanical.
Any other ideas?
Any other ideas?
I have had trouble with hard shifts in the past when I had my boost gauge vacuum line come loose.
And then I had hard shifts and torque converter not locking up.
I did finally notice I had a P0607 code and I replaced the barometric pressure sensor under the dash and my transmission problems haven't been back for several months.
Kevin
Kevin
I solved the problem!
Earlier I said I replaced the Range Sensor, which was a mistake. I meant to say I *bought* one. Today, I got under the truck to actually replace it, and the range sensor was extremely loose (I could twist the bolts with my fingers). The shifter cable was also rubbing against part of the frame, because the sensor itself wasn't seated correctly. After replacing everything and tightened it all down, I noticed several problems were fixed:
- My shifter in the steering column is significantly more stiff
- Truck starts in park (finally)
- Shift points were much more firm
- Erratic shifting has disappeared
- Mystery squeal that I assumed to be a bad wheel bearing disappeared (it was the cable against the frame)
