78 Tilt Column Bearings
Folks,
I recently looked at reducing my steering wobble. When I took the column apart, I couldn't remember if there was an upper and lower tilt column bearing, or just an upper. The bearing I am referring to is right at the tilt joint at the steering wheel.
I have an upper that looks like this:
1974-1979 Ford Bronco and F-Series TruckColumn Bearing, Upper-Broncograveyard.com
However I'm not sure if there is a lower, and if so, how is it retained?
Folks,
However, there is a lower, and if so, how is it retained?
Upper and lower bearings are shown as 3517. The lower bearing also uses a sleeve (3518). 3D681 is the lower bearing retainer.
Lower bearing retainer comes with the bearing & sleeve that were also available individually.
D3TZ-3D681-A .. Lower Bearing Retainer - Tilt/non tilt makes no difference / Obsolete
1973 F100/250 4WD & Bronco from serial number S20,001 / 1974/79 F100/250 4WD & Bronco.
No Ford dealer or obsolete parts vendor has any. Try Bronco Graveyard.
F23Z-3517-B (replaced C7SZ-3517-D) .. Upper & Lower Steering Column Bearing-1978/79: Use with Tilt Wheel / Available from Ford.
1978/79 F100/350, Bronco & Econoline / 1980/91 F100/350, Bronco & Econoline (upper only-with/without Tilt Wheel) / Misc. 1967/97 Passenger Cars.
Loosey-goosey steering can also be caused by worn steering track bar bushings (3B116), drag link (3304), right tie rod (3289), left tie rod end (3A131), steering shock bushings (3E655).
And, if you bought an auto parts store steering gear box, it's nothing more than a resealed gear box.
Ford/Saginaw P/S boxes have a flaw, there are no bearings on the sector shaft, it rides directly on the housing.
So, before too long, fluid begins leaking from the sector shaft seal. Not pleasant!
redheadsteeringgears.com takes the housing, machines it to install the sector shaft bearings that Ford omitted, so they could sell a gazillion sector shaft seal kits!
Pic shows single shock front suspension, dual shock is similar.
I have two bearings already. The upper one in blue is the smaller of the two. The one that fits in between the two jaws is larger in blue. There appears to be a machined surface that can accept another bearing, but I'm not sure if it's supposed to have one. When I try to slide the upper in the place, it physically can't clear the shaft. The shaft appears to be deformed slightly.
Is there supposed to be a 3rd bearing there where the red arrow is? If so, how is it retained?
Jmwinter
31
07-08-2020 03:41 PM
CountryBumkin
03-30-2017 07:29 AM
DaytonaTunnel
10-14-2016 12:04 PM
OX2
15
08-01-2012 05:14 PM
66crawler
13
08-28-2010 12:16 AM
