park brake assembly
park brake assembly
hey, so I have a 1979 bronco and the park brake doesn't work. when i press the pedal its loose and doesn't lock down. i think the teeth on it are stripped but im not sure. i was wondering if there are parts to fix it, or maybe a new replacement assembly. do any other model f series or broncos fit? i know the 73-79's should fit but those are hard to find at the wreckers haha
The front cable that attaches to the control is a separate part.
D6TZ-2780-A .. Park Brake Control / Obsolete
1976/79 F100/350 & 1978/79 Bronco.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
Lower pic:
Not to hijack the thread, but the schematic by NumberDummy just solved the mystery of why my parking brake doesn't work correctly.
I never knew that the spring 2A651 under the chassis existed(mine didn't have it when I rebuilt the system) but I knew I needed something there, so I bought an assortment of brake springs that I was going to try installing on that cable junction but the springs I bought were incorrect size. Is that spring available and would anyone have some pictures of it installed?
Thanks for your time!
I never knew that the spring 2A651 under the chassis existed (mine didn't have it when I rebuilt the system) but I knew I needed something there, so I bought an assortment of brake springs that I was going to try installing on that cable junction but the springs I bought were incorrect size. Is that spring available and would anyone have some pictures of it installed?
No Ford dealer or obsolete parts vendor has any.
1973/75 F350 Regular Cab 160" wheelbase & 166" wheelbase Crew Cab / 1974/75 F250 2WD & F350 Super Cab / 1975/79 E150/350 / 1976/79 F100/150 / 1978/79 Bronco.
Thank you for that. Would you happen to know it's mounting method or have access to a picture that would show it? Maybe I can still make something work with the brake springs I purchased.
[EDIT]Found one for sale on eBay and figured out it connects via the eyelet on the pedal-side cable and frame so i think I can figure out how it goes together. Thank you very much for all your help on the part number!
StepSide1978
22
06-04-2019 06:48 AM
dhglaser
04-25-2012 12:04 PM
Rusty_Old_F250
15
10-05-2010 09:42 AM
