1948 Ford front spindle bearing???
Old 07-26-2016, 10:44 AM
pezsox's Avatar
pezsox
pezsox is offline
do these bearings need greased before installation? or do they just get the grease from the zerks when installed? If so, what do you guys recommend?
Old 07-26-2016, 11:30 AM
GLR's Avatar
GLR
GLR is offline
Always a good idea to grease or lube any part before installation.
Old 07-26-2016, 11:46 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
They're sealed, no way to get grease in
Old 07-26-2016, 12:05 PM
GLR's Avatar
GLR
GLR is offline
Wish I was near my parts right now. If CRS hasn't sunk in...isn't there an open "groove" in the inside of the bearing for grease to get into?
Agree that if the bearing is sealed you can't really lube it.
Old 07-26-2016, 12:11 PM
GLR's Avatar
GLR
GLR is offline
https://www.google.com/search?q=1954...wSDccMqtFfM%3A
Where it says related images, click on the 2nd from left, top images.
Old 07-26-2016, 02:20 PM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
They should get grease from the bottom grease fitting. They are open on the inside and the bottom race has clearance around the kingpin for grease to come up from the lower bushing. The second photo is the correct way to install them.
Mark
Old 07-26-2016, 03:19 PM
GLR's Avatar
GLR
GLR is offline
Mark
I didn't think they were "sealed"
Old 08-29-2017, 12:50 PM
1995_F150_5.8's Avatar
1995_F150_5.8
1995_F150_5.8 is offline
As you can see in the pic [...]
87907-S8 (8 not shown in pic) is the right Zerk (lubrication) fitting, 87922-S8 is the left Zerk fitting.
Since there's no specs listed in the catalog, these are a press fit into the spindle holes.
GREEN SALES CO. in Cincinnati OH (800-543-4959) has 1,209 87908-S8 & 9 87922-S8
I'm a great big Nerd and i'm doing king pins - My 'Lubricator Fitting' in my '57 M250 is the same part number (87922-S8) as your Left Zerk fitting above and is threaded. I looked here first for the thread spec and stumbled upon your post.
I very much enjoy your posts, and you're right more than 99% of the time - But, this time i beg to differ.
87908-S8 1/4-28 : 11/16 long : 15/64" thread length
: type 2 (straight)
87922-S8 1/4-28 : 31/32 long : 15/64" thread length
: type 3 (45 degree)
Bottom left, page 4
Ford Standard and Utility Parts, May 1954, Form 3733
Two points for me?
Old 08-29-2017, 04:30 PM
itsnotavan's Avatar
itsnotavan
itsnotavan is offline
Liebherr cranes have a similar set up for there thrust bearings. Also a equally nondescript illustrated parts brake down. After some Q&A with tech support and field reps one suggested to measure the inside diameter of the "top" and "bottom". The larger of the two openings would be installed towards the Zerk. Idea being the overflow from the greased stub pin would flow into the thrust bearing.
Old 08-29-2017, 07:01 PM
3twinridges's Avatar
3twinridges
3twinridges is offline
I just installed NOS bearings in my spindles and they were open. I packed them full of grease by hand before installing the kingpins.
JB
Fireball573
11-25-2009 04:55 AM
Billyclub
17
08-28-2009 01:31 AM
Dstosh
01-26-2009 06:40 PM
JasonI
11-13-2008 04:36 PM
Quick Reply: 1948 Ford front spindle bearing???
