Please Help!- Spindle Bearing Installation
Old Jan 26, 2009 | 06:00 PM
Dstosh's Avatar
Dstosh
I have found the source of the grinding in my front end. The passenger side spindle bearing was completely gone. I tried to get a new one in there and it would only go so far. I ended up destroying the bearing trying to get it in. How far does the bearing have to go in to to the actual spindle? The seal that it came with looks as if it sits down into the hole somewhat.
See pic. Does the bearing go all the way down to the bottom grove/built in race? Thanks
Old Jan 26, 2009 | 06:15 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
Check the thread originally posted your question in, I described my method of installing spindle bearings. Good luck!
Old Jan 26, 2009 | 06:40 PM
stroked bronco's Avatar
stroked bronco
from the loks of your pic. the bearing race is still in the spindle, you will need to get it out before you try putting the new one in
