Calling all radio experts (Factory Aux Question)
I recently installed a 2005 Mercury Grand Marquis factory radio into my 2004 F-250. I like everything about the stereo, except for the fact that it does not have an auxiliary input. It has the connection on the back for a cd changer or Rear-Seat Entertainment, but no aux button. Nonetheless, I tried using a PAC AAI-FD4 input adapter (plugs into the back of the stereo fine). I tried pushing CD twice, and all I get is "No Disc" or "No CD" or something like that. It plays CDs fine, but it won't recognize this adapter. I tried the adapter with a CD-6 unit with CD/Aux and SAT buttons, and still no luck.
Is there any way I can get a hardwired Aux input for this Grand Marquis Radio? I don't want any FM Modulated hardware, nor do I want an aftermarket head unit or double-din conversion.
The stereo I am trying to get Aux input to (P/N 5W7T-18C815-AF):
The CD-6 Unit I also tried (P/N 4L1T-18C815-AE):
The Adapter I have:
Thank you for your help,
Doug
The Adapter I have:
Doug
Sticking a CD in results in the CD playing, pushing the CD button again does nothing. That trick I think is usually for diy splicing the audio wires in a cd changer. The audio comes from the aux input, but the head unit thinks it is playing the cd audio.
In this application, the PAC adapter should emulate a changer and the head unit should recognize it as an audio source.
Just looked him up and he does have a lot of good looking, very clean radios. I like that he also offers some with a pigtail so you can mount the female plug in the dash or a console so you don't have a wire sticking in the face of the radio. That being said, there has to be a way to diy to save some money. Most seem to be around $185 and that doesn't sound bad, but if you already have the radio or just want to diy, I think it could be completed much cheaper if you just had a wiring diagram.
I own a business. People pay me to do a specialty that they cannot. I have no problem paying someone to do something that I have no expertise with.
My time is valuable as well but I also enjoy finding solutions to problems just like this, if nothing else, just to learn something new. Saving a few hundred dollars doesn't hurt either and also means I can pay myself for my hard work instead of someone else.
I'll figure it out and post instructions for future forum members to use.
I always like it when someone on these forums finds a solution to an issue and shares the knowledge.
I've never had one of these radios apart. But from looking at the exterior of one that I purchased from the ebay guy, I'm thinking that he probably taps into a circuit board for the input somewhere along the line. If so, that means that it's something that a person with my electronic and soldering ability should probably avoid!
In my (admittedly) limited experience, the AUX input is intended for satellite radio input. In which case, I think you may be using the improper adapter. Look into the
FRDN-AUX adapter. Here is some more information, hope it helps.
Lincoln auxiliary audio input interface adapter add aux mp3 iPod
twom7
10-06-2012 10:51 AM
psu1xj
08-19-2004 07:18 PM
AKESPY
04-26-2004 05:25 AM
