89 F-150 Neutral safety switch issue?
I have an 89 F-150 with the 351 and auto trans. The truck has only been able to start by turning the ignition switch on and then fiddling with the gear shift lever until it hits the sweet spot. Not really a big issue, but bothersome. So, I looked into aligning the neutral safety switch. Ford suggests to use a #43 drill bit (who would even have one of those??) and line up the 3 holes in the safety switch. I did that about 2 years ago and it worked ok for awhile. Now, I lined them up with a right size nail and though all 3 holes now line up, now nothing at all happens when I turn the ignition switch, even while fiddling with the gear shift.
I can start it by jumping the 2 bolts on the solonoid switch under the hood. Question is...does doing that bypass the safety switch? Do I need to replace the safety switch? The truck has about 102000 miles but probably lived a pretty hard life before I got it. Thanks!!
Received 3,113 Likes
on
FUJINAMI1293
01-12-2017 07:10 AM
84F150driver
06-14-2010 09:14 PM
MTrumpy
07-19-2007 08:08 PM
