Neutral Safety Switch Problems
Old Jul 18, 2007 | 09:31 PM
MTrumpy's Avatar
MTrumpy
I have a 79 Ford F 150 Automatic 2 wheel drive. It would start in any gear. So I replaced the NSS. I then tried to start my truck but had nothing at the ignition switch. The NSS not only would not let the truck start in gear, but not in park or neutral either. Any ideas as to what I need to do so the neutral safety switch works correctly?
Old Jul 18, 2007 | 09:37 PM
CLR f-150's Avatar
CLR f-150
well i have a 77 f 150 and the problem with mine is that everytime that i want to startmy truck i have to take my shifter colum and swing it all the way down to one and then back up to park to start my truck so my problm is similer but i not sure what you can do accept check everything.
Old Jul 19, 2007 | 12:11 AM
Mil1ion's Avatar
Mil1ion
In 78 moved the NSS from the column to the side of transmission
You have top go down to the transmission and set the NSS to thre correct position.
It requires a 7/16" or /2" wrench.and drill bit.
Chock tires
Place trans lever in neutral
Loosen Trans lever at transmission
Turn NSS and slide 1/8" drill bit into NSS until it goes thru the switch
Tighten NSS
Remove drill bit
Start in Neutral or Park
Old Jul 19, 2007 | 05:52 PM
MTrumpy's Avatar
MTrumpy
I will try that.... I forgot to mention that there was a jumper wire wired into the harness connecting to 2 pins....I guess to defeat the original safety switch.. The ignition switch was also replaced. I was wondering if something could be wrong here.
But I will try what you explained with positioning of the switch and drill bit. Thanks
Old Jul 19, 2007 | 08:08 PM
Mil1ion's Avatar
Mil1ion
MONAVIERONJON
15
Jul 29, 2021 08:27 PM
BainbridgeBrewer
Jan 2, 2017 03:50 PM
Carolina_FoMoCo
Aug 20, 2016 01:37 PM
D & D
May 5, 2016 08:24 AM
dmccorkle911
Sep 24, 2015 07:30 PM
