Now, my 95 4.9 (300) hence my username, won't run right. The only trouble code I'm getting is 327. I've done lots of research and are basically at wits end because I dont know what to do, or where to start doing it. I've found other posts about it, but nothing will help me! Basically, it's telling me that the EGR valve is functioning properly, but the computer can't read it. / some sensor is getting low voltage. Id take any help I can get, I just need to know what to do and where to start!
In my, and other people's opinions I'm a pretty good mechanic. On smaller stuff.... I CANT STAND all the electronics and sensors on new vehicles. They're there to help, but 15-20 years later simply screw you over. But I'm hoping to get a fix, and post it here to help anyone in the future. Thanks.
Why create a post for the same topic? At least you posted a link to the old thread. Based on your Code list (A mix of two and three digit) your hypothesis of what the code is may be flawed. Until you can pull valid codes, your 1995 should have three digit codes, you are chasing your tail.
Because I now have the codes, if someone sees this sublet rather than the other, I may have a better chance. It's the same, yet different. I did end up getting 111,111,327,327. This is more of a subject in codes, rather than the simply not running right. Also, if I had as much problem as I did trying to find info on it, I want to help other people out in the future if I can.
