Inner fender mixup
I guess it all depends on how you define "wrong". Most of my builds have custom inner fenders because I like a clean look. If you are doing a restoration then I wouldn't attempt to make a different inner fender work. This is just sheetmetal, the fit is not critical...I would say go with what you like.
Original 1
Part of why replacing original 1
Replacement without cutouts
Original 2
Aftermarket, from other year?...seems too long. No holes for radiator support but appears holes line up with inner fender brace. ..
Not a restoration....
I was thinking of making a template of the holes on the original inner fender and cutting the front end of the aftermarket and drilling holes... Just seemed odd that one year might be longer to mount the fenders, the bottom part nearly matches the framerail....
If you have run these aftermarket fenders, did you fab something up to hold the bottoms in place at the rear? I think I got them from hot rodz years ago and then found out they were for a different year, 53 vs my 52...
Just from memory, 48-50 inners are longer overall. 51-52 are the same except that '51's have a dog leg at the lower rear where they bolt to the frame (and promptly rip when the frame flexes). It looks like your "OEM without cutout" and "original 2" are '52's.
Here is a '51 with the dog leg
Here is a pic of my latest mock up, it's a little difficult to see behind the engine but hopefully you can get an idea of what the process looks like...
jerry_s
04-21-2018 02:58 PM
jrockdiddy
19
12-28-2017 08:39 PM
firstrider
08-06-2009 09:46 AM
