Are swing away mirrors from the 80's and 90's the same?
If I'm not mistaken, the Swing Away mirrors with an F0 part number don't come with the gasket. The mirrors look identical with an E5 part number from the 80's, but come with the gasket.
Are they the same with identical door mounting points, or did Ford actually change something?
1973/79: There were FOUR different types using THREE different mirror heads.
The span between the upper and lower brackets could be 6 11/16" or 7 27/32."
And, one type has curved brackets, t'other has flat brackets.
TYPE 8 was introduced in 1975 as part of the Camper/Trailer Special package, optional on other trucks and Econolines.
If you're referring to TYPE 9 Low Mount Swing-Lock mirrors, 1973/79 is not the same as 1980 and later!
Plus...there's another right side...with a convex mirror glass.
These are chrome mirrors, the mirror head measures 5" x 8."
E5TZ-17696-A .. Right TYPE 9 Mirror with Aero Head / Obsolete ~ 2 available NOS
E5TZ-17696-B .. Left TYPE 9 Mirror with Aero Head / Obsolete ~ 35 available NOS
E5TZ-17696-C .. Right TYPE 9 Mirror with Aero Head with convex mirror glass / Obsolete ~ 1 available NOS
The suffix is missing from this mirror, and it's very important, as due to the aero mirror head, there is a right & left.
Brad, on the later 80's mirrors e5tz-17696-a/b, the bracket is below the arm well. Thats why I thought they were the same.
Yogi-96blazer
13
03-10-2007 11:59 PM
