At wits end!!
Old Jul 8, 2016 | 09:41 PM
vadonkey's Avatar
vadonkey
At wits end!!
I purchased a 96 F150 supercab 2wd a few months ago. When I test drove it, I took it up to about 50mph and all seemed well so I bought it.
I have been dealing with a vibration/shake at 60+ mph and can't seem to get a handle on it.
Here is what has been done/replaced
Tires replaced (balanced 2x)
new front shocks
all steering components replaced
wheel bearings repacked
ujoints/ carrier bearing checked 2x by mechanic
rear shocks are air and hold air fine
ball joints seem OK....no play noticed
radius arm bushings replaced before I bought it...blue polyurethane and seem tight
No unusual noises/clunks etc
I haven't checked pivot bushings...not sure what the symptoms of bad bushings are.
and ideas/help is greatly appreciated!
Old Jul 8, 2016 | 09:50 PM
jplinville's Avatar
jplinville
I had the same issue, and chased it to the rear drive shaft. Previous owner parked it on a boulder, very hard, and dented and bent it. It's currently at the shop, have some tube work done and new u-joints. I hope it fixes it for me.
Old Jul 9, 2016 | 08:58 AM
tjc transport's Avatar
tjc transport
i ain't rite
how did they check the universals? i have seen many many trucks with vibrations that had the universals "check good" and when i drop the drive shaft the universals fell apart because they were so dry the needle bearings were dust.
Old Jul 9, 2016 | 11:46 AM
Nero Morg's Avatar
Nero Morg
When I was in AZ I did the U joints in my driveline, 2 piece driveline with a carrier bearing. Some dip**** at the shop decide to give it a love tap with a hammer while I wasn't looking, and after that I had a pulsing vibration at any speed over 45. Had the driveline straightened and balanced fixed her right up. Sounds like a similar issue if you already went through the rest.
Old Jul 9, 2016 | 12:31 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Brake rotors also have been known to cause a high speed shake ...
-Enjoy
fh : )_~
Old Jul 9, 2016 | 04:09 PM
vadonkey's Avatar
vadonkey
I don't think the shops pulled the driveshaft to check the universals, their answer was "Ujoints are O, you need tires balanced"
I have not looked for the weight on the driveshaft, I'll climb under there and look for the weight (or lack of).
Could the transmission mount be a possible culprit?
Also, how would you test for the pivot bushings being worn....is vibration a symptom
Thanks for the replies and suggestions...much appreciated
Old Jul 9, 2016 | 04:18 PM
Nero Morg's Avatar
Nero Morg
I doubt the weights fell off, as they are held in by a good sized spot weld, and then typically painted over to prevent rusting. It's hard to tell if I driveline is warped slightly or out of alignment. Something simple as 5/1000in out of being straight can cause vibration at high speeds. Brakes can cause vibrations, but usually don't vibrate until you apply the brakes.
As for the Trans mount, it could be. There's just the one crossmember mount holding it in place, the rest of the support is attached to the engine.
Someone else will have to chime in on the pivot bushings.
Old Jul 9, 2016 | 06:09 PM
tjc transport
i ain't rite
if they did not pull the drive shaft out to check the universals, i would do it myself. the only way to visually check universals is if you see rust at the caps. but that is not proof positive they are good or bad.
i chock the wheels, drop the shaft, and check for easy pivot and grease in the caps.
and every driveshaft i have pulled to check u-joints had at least one of them bad, usually the rear joint
steve(ill)
1997 - 2003 F150
Mar 3, 2016 04:29 PM
randyj68
Feb 24, 2015 04:15 PM
endobear
Nov 17, 2014 11:19 AM
x.l.r.8
Aerostar
Aug 7, 2005 09:47 PM
jbjb5081
May 30, 2004 12:28 AM
