Swapping transmissions
The short answer is yes. The long answer is you need a SBF bell housing. Plus what ever it takes to make the hydraulic clutch work. Plus making a cross member to work with the T19 and then making up drive shafts. The Zf-5 in my mind is a better transmission. So why would you want to go back to a 4 speed
IIRC it's a different length (both front and rear) drive shaft as well.
Appreciate it man the more I know the better. Any clue why my transmission grinds in reverse. Goes Into reverse but grinds while I'm letting off clutch
meangreen92
08-10-2021 07:57 PM
micman7
01-10-2011 09:02 PM
