Auto Trans Fluid Change Write Up?
Hoping someone has a link to a write-up on changing the auto tranny fluid. I googled but came up short. Up to now, I've been cleaning up the underbody to prep for this, but figured it's be nice to see a demo before I tackle it this weekend. Any help or advice would be appreciated. For reference this is for a 360 automatic 72' F250.
-Mike
-Mike
Automatics fill from the dipstick in most cases. Some newer transmissions are different.
You could also use this: Changing ATF Fluid in a E4OD and 4R100 transmission - Ford-Trucks.com
If it's the original C6 then you definitely need type-f. Recently rebuilt then Dexron/Mercon will do the trick, which was recommended for my new C6.
If you don't have a '72 Ford truck shop manual, you need to get one. It will have all the fill capacities for the various items on your truck as well as other valuable information on how to work on it. --consider the manual as a tool that's just as important as the wrenches, sockets and screwdrivers you use to work on the truck.
The Ford shop manuals can be bought in hard copy form or on CD.
Backwoods351
35
08-30-2014 05:13 PM
coppertales
01-29-2007 05:11 PM
