Auto trans fluid flow.....
Old Jan 19, 2007 | 02:30 PM
coppertales's Avatar
coppertales
On a 96 F150 302 auto, does the trans fluid in the pan cycle through the torque converter as well as through the tranny? I can't seem to find that info in any of the manuals I have. If I recall, and it has been a looooong time, I think the old Pontiac hydros did. It has been 45 years since I went to General Motors training center......thanks....chris3
Old Jan 19, 2007 | 05:54 PM
subford's Avatar
subford
Yes it does.
Old Jan 29, 2007 | 07:10 AM
coppertales
Thanks....
I have been changing my tranny fluid every 30000 miles. I suck it out the dipstick tube and refill it. Truck has 126000 miles and the auto trans works perfectly....after all, tranny fluid is rather cheap......chris3
Old Jan 29, 2007 | 07:34 AM
subford's Avatar
subford
You may want to change the filter at some point.
Old Jan 29, 2007 | 10:42 AM
bohiaa's Avatar
bohiaa
3000 Miles HOLY CRAP
I dont even change the engine oil that offten
the trannie in my 93 uses 21 qts
including the TQ
that is a bit expensive
Old Jan 29, 2007 | 11:03 AM
subford's Avatar
subford
including the TQ
He said 30000 not 3000 and how do you put 21 qts in a 93.
Old Jan 29, 2007 | 12:10 PM
quicklook2's Avatar
quicklook2
that is just crazy.
you need to just drop pan, drain convertor and put in a new filter.
doing it the way you say does not get all the fluid out, it does not clean the magnet in the pan, and the filter is not replaced.
what you are doing is not really helping.
Old Jan 29, 2007 | 04:58 PM
teenagegearhead06's Avatar
teenagegearhead06
I think that it is helping alot by keeping clean fluid in it the filter should last alot longer and clean fluid will keep wear down. i'd say though the filter is due for replacement though
Old Jan 29, 2007 | 05:05 PM
quicklook2's Avatar
quicklook2
but taking it out the filler tube?
Old Jan 29, 2007 | 05:11 PM
bohiaa's Avatar
bohiaa
ummmm that's what it holds.....
if ya drain the TQ
