Drawbar/hitch/pintle lock?
Back in 2004 when I got my pintle I also got a lock for it, because a brand new pintle with no lock seems like something that would grow legs.
I did pretty much zero research and bought a Master Lock unit that was stainless steel. I figured that would serve me well. It looked very similar to this one:
https://www.amazon.com/Master-Lock-S...ter+lock+hitch
Well, in the first couple years I took it on and off a few times, but most of the time it just sat there. After my second winter, it was seized and would not come off. I left the pintle on my truck until a month or two ago when I cut it off with a grinder.
Now I would like to put a lock on my 2016. I'm asking for recommendations for a lock that will continue to function for years without seizing.
I really like the codeable models like this:
https://www.amazon.com/Durasafe-CRL6...ble+hitch+lock
But again, it's only worthwhile if it's going to continue to work for years and years.
I'm also thinking about just welding something to the end of a normal hitch pin. If I'm going to have to cut it off with a grinder anyway, I might as well go cheap with it.
-J
-J
I wouldn't use wd-40 it will hold the dust and dirt, a dry graphite lube would be be better.
A lock at the rear isn't a set it and forget thing, to much road dedris, dust, moisture and such. Periodically cleaning/lubing will go a long way.
On a side note how many times do you walk into it fogetting it's there.; (
I never had a problem running into my pintle. It was ALWAYS there, so you get used to it. I've seen some other people get whacked pretty good though.
-J
I agree completely about the WD-40. I had some aerosol grease that I've used on all sorts of things outside, I used that on my Master Lock pin that I bought in '04. Maybe that wasn't the best thing to use either. I think I'll have to try Graphite. I did do SOME maintenance on the old one, but during one stretch of probably 2-4 months it seized up. I was in NJ at the time, with more snow and more road salt. Hopefully now that I'm in Arkansas it'll be better.
I never had a problem running into my pintle. It was ALWAYS there, so you get used to it. I've seen some other people get whacked pretty good though.I guess I'll try it out. What do you use for lube?
-J
-J
I would not recommend leaving your hitch draw bar in the receiver for any length of time unless you live in the dry southwest. Some states even have laws against it. That said if you do I would remove it monthly and clean and relube the shank to prevent it seizing in the receiver, I have made a lot of beer money from those that did and found that all of a sudden they needed to remove it that it would not come out, had 1 that actually bent a 20 ton press without moving. Normally I use a torch to slice the inner tube and then collapse it to be able to get it out, the 1 that bent the press was a solid 2 1/2 in. shank and had only been in for 2 months, we had to replace the receiver to repair it. Your choice but at least keep it lubed.
Anyway... I'm too lazy to take it out. It rode around in my '04 for 11.5yrs without getting stuck and 3 of those were in New Jersey. I think it'll be fine down here. I will keep an eye on it though.
I ordered the codeable one, I'll put some graphite in it and try to remember to remove it every few weeks. We'll see how it goes. The worst thing that could happen is it will be seized on my '16 the exact same way it was seized on my '04 and nothing bad came of that.
-J
Off topic, sorry. But how hard was it to grind off? I ask because I have one of those holding my front license plate in my front receiver hitch, but I have lost the keys. What side/where did you grind. I'm a little concerned because there isn't a lot of room to work in the front. I had considered trying to knock the lock off with a steel chisel and a BFH, but I'm not sure that'd work. I was also considering drilling out the lock cylinder.
I used my 4" angle grinder with a cut-off wheel. It made pretty quick work of it, but it did jump around a little. I would imagine the tighter area on the front of the truck might make it a lot harder. I cut it on the side that the key goes on, as close to the hitch as possible. I cut through the entire lock. Once I was done, I used a punch and a couple taps from a hammer and drove the pin out of what was left of the lock.
Cutting it off of the back wasn't a big deal.
-J
-J
wrvond
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
03-31-2018 01:08 AM
bobv60
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
05-09-2016 11:32 AM
