06 ford explorer
06 ford explorer
I have a 2006 ford explorer 6 cylinder. It has been giving me trouble. It started running rough after a trip to TN. Took it and had thrm put it in machine. They said EGR valve. So i changed it. Now it running worse. Stalling or trying to stall. Take it back they say it could be a couple things. The o2 sensore or a hose clog. Im at my wits end and cant keep putting moneykeepthis truck for them to keep guessing.
There are virtually no codes that state exactly what part is bad, only which system is reporting out of specification values to give the technician a place to start with their diagnostics. If you go to a parts store and they say, "You need a new EGR valve" you should be hesitant and instead ask for the exact code number to do further diagnosis.
Did you happen to get the exact code numbers, and if so, please provide them.
-Rod
-Rod
Misky6.0
06-06-2011 11:15 AM
JTD1972
05-23-2004 12:05 AM
robask
10-24-2001 11:20 PM
