Death Wobble? Violent shaking when braking
Hey all,
So I have a '94 F350 4x4 E4OD 7.3 IDIT 200k+ that has developed a death wobble of sorts. I've done all the routine fun stuff, brakes all around(everything from drums to wheel cylinders, rotors, and pads, no calipers though, still good), front shocks, front wheel bearings(inner/outer, seals), tie rods, aligned, balanced, new rear parking brake cables, ball joints are still good(Moog), I think that's it… Everything is adjusted and lubed, however my steering gearbox is leaking and time for a Redhead replacement.
Would that cause the wobble? There is a gentle shake as I drive down the road but when I touch the brakes, the shaking really begins. Light at first then violent and uncontrollable as I press harder. I am using the tranny to slow me down because it is awful… My ABS light is on(still haven't done the cruise switch recall), proportioning valve perhaps? Not even sure where to start at this point, what do I focus on first??!
Thanks all!!!!
Thanks all!!!!
It took 6 months to cure Death Wobble on my 2012. A very long story short the steering box resolved it. My problem wasn't when braking but hitting certain road imperfections. The box had a weird feel and would clunk @ 10 and 2 oclock and Ford said it was normal.
Not saying it's your cure as there's many other things that can cause it, just answering your question with facts.
You missed the most critical part that causes death wobble on these trucks, all the bushings and most importantly the tracbar bushings will make this thing undrive able.
Start with the tracking bar then the spring bushings and shocks if you haven't already and last resort if you want to cover up the problem add a steering stabilizer.
Still shaking after...
So, I've replaced almost everything up front. All bushings except spring bushings, new gear box, alignment, balanced, new rotors, freshly turned. Ball joints are not new but they aren't bad either. Only happens when braking, and the guy that turned my room said the front right caliper would lockup on him. This never happened to me, but now if I hit them brakes hard at lower speeds, I can lock up that tire. Could it be something in the rear brakes? The whole truck shakes, not just the front. ABS related? My light has been on forever… I'm lost, getting mad at her now, help! Thanks!
Brakes should NOT lock up when applied.
have you had an alignment?
And you have your NEW rotors turned?!? why.
Received 3,115 Likes
on
on
Personally, I think the term death wobble is miss used here.
One doesn't usually feel death wobble until something like a pot hole starts it a wobbling, then it goes berserk in a hurry, is barely controllable and nothing stops it until the vehicle slows down to almost a stop.
-Enjoy
fh : )_~
-Enjoy
fh : )_~
I had the same issue. I did the same things as you. Bearings, drums, rotors, bushings...blah blah blah. I even had my tires balanced (at least they said they were).
Finally, I took it to a shop for a diagnosis. They said the right front rim was bent. Sure enough, after replacing the rim the problem went away never to return. Easy enough to rotate your tires to check. It costs nothing and is something that needs to be done periodically anyway.
when you replaced your front end parts did you also replace the rubber lines to the calipers they can look perfectly fine and still be bad the inner linning can seperate and not release the pressure and you will get that wobble the main cause would be crimping vise grips on the line to keep the fluid from leaking
-Enjoy
fh : )_~
-Enjoy
fh : )_~
I also agree with Brad, it shouldn't be locking up one the front tire. There is something wrong there or in the ABS system. You said the ABS light is on, for the PS recall, however, are you sure there isn't another code in the system as well. One code can turn the light on, doesn't mean there aren't other codes as well.
